200 es honda no spark
Old Sep 23, 2006 | 01:15 AM
woffler's Avatar
Default 200 es honda no spark
all of a sudden no spark wasnt hot just started then failed checked plug ok ? any suggestions glad i found you guys trying to restore 200es need it on the ranch
Old Oct 3, 2006 | 07:19 PM
longbedgts's Avatar
Check for loose connections. Have you verified the coil is good? Is the spark plug wire making good contact with the spark plug post? Check your grounds and just go over everything with a fine tooth comb. Good luck!
Old Oct 3, 2006 | 07:41 PM
HondaAtcRoxz's Avatar
WELCOME TO THE FORUMS!!!
Also be sure to check your wires commin out of the bottom end. They are very prone to go bad.
HondaAtcRoxz
dirt ryder
Sep 27, 2015 09:22 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
CRamshaw777
Jul 18, 2015 05:46 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
