oil filter counter clockwise to loosen?
Old Sep 23, 2006 | 10:44 AM
xgagne55x's Avatar
Default oil filter counter clockwise to loosen?
any oil filter i have ever changed has come off counter clockwise is this true with kawi. doesn't seem to wanna budge
Old Sep 23, 2006 | 11:07 AM
FASTFATBOY's Avatar
Yea counter clockwise to loosen. If it was put on pretty tight and you can't get or don't have an oil filter wrench you can get it off the red neck way by driving a screw driver thru the filter and use the handle for to turn the filter. I've had to do that several times on a little bit of everything. If you give it a try just make sure you go to the end of the filter so you don't damage the threads where you screw on the filter. An oil filter wrench is safer but if you don't have one than this will work. Also that is why I like k&n oil filters they come with a bolt head attached to the end of the filter just incase something like this happens.
Old Sep 23, 2006 | 11:32 AM
xgagne55x's Avatar
yeah i've used the screwdriver routine before, but i did'nt wanna drive one thru and then be a idiot and tighten it more. thanks
Old Sep 23, 2006 | 02:31 PM
RAMBLNMAN's Avatar
if you take a leather waist belt put it thru the buckleand cinch it tight and pull it should loosen it a cheap mans oil filter wrench!
Old Sep 23, 2006 | 02:41 PM
FASTFATBOY's Avatar
Damn you guys from New England are starting to change my opinion of yankees. I thought the screwdriver and belt trick were pure redneck. Redneck meaning they were invented and primarily used by hairy guys named Bubba who's butt hung out of his pants. If ya'll know about these tricks and use them then ya'll must have a little Redneck in you too. And if that's the case then I guess yankees aren't all that bad after all. LOL
Old Sep 24, 2006 | 11:48 AM
xgagne55x's Avatar
yeah not a whole lot of city slickers here i was at work last night with the guy i ride with and he uses the belt routine all the time. gonna go snag my girlfriends belt
Johnny Mac
Aug 15, 2019 03:13 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
