Wolverine Baffle/Rejet?
Old Sep 26, 2006 | 09:47 PM
dylan's Avatar
Default Wolverine Baffle/Rejet?
If i take the baffle out of my wolverine will i have to rejet?
Old Sep 26, 2006 | 10:09 PM
tdragano's Avatar
My guess would be no.
Take your plug out before hand and take a good look at it. Reinstall the plug
Remove the baffle and do a couple full throttle passes and kill the motor while still wide open (you can lift up on the shifter, hold it there and coast to a stop). Pull the plug and make sure it hasn't turned white, which would indicate that you are lean. If the plug has turned white, you will have to go up on the main jet (1) size.
Old Sep 26, 2006 | 10:26 PM
dylan's Avatar
Huh, i never knew that was the way to see if i was running lean, thanks for your help on both of my posts tdragano.
Old Sep 26, 2006 | 11:03 PM
tdragano's Avatar
dylan,
Try the following Search under the Advanced Search:
Under "Main Search Criteria", Search Phrase use Wolverine and Jetting
Just select "Title" using the "In" drop down
Don't worry about any Filtering options
Under Forum Categories, just select Yamaha
Click the Search button on the Left side of the page, about 1/3 of the way down.
The first hit will be by GlennJ, we hit that one pretty thorough. Check them out, you'll find most anything you ever wanted to know about jetting a Wolv. If you don't see what you're looking for, just holler.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
