Wiring Diagram
Old Oct 2, 2006 | 06:03 PM
4TACXOMA4's Avatar
Default Wiring Diagram
Hi, new here...my dad just picked up a 1986 Honda Fourtrax 350 4x4, and he is in need of the wiring diagram for it. Is there anywhere to view this online, or must it be purchased. Thanks for any help.
Old Oct 3, 2006 | 07:40 PM
bombrider04's Avatar
Honda didn't have the 350 listed so here is the only site I know that would have it or just go to a honda dealership and ask for a page to be copied from the service manual they should do it if they are nice. But you can get an idea from the wiring from some of the older quads.
http://www.ronniesmailorder.com/fich...17&classID=atv
Old Oct 3, 2006 | 08:52 PM
HondaMechanic's Avatar
none
Old Oct 4, 2006 | 01:39 AM
4TACXOMA4's Avatar
Originally posted by: HondaMechanic
Here is a wiring diagram for the 1986 TRX350D .. If this isn't clear or large enough PM me your email address and I will email you a PDF wiring diagram
TRX350 wiring diagram
Thanks. You've got a PM.
Old Oct 16, 2006 | 09:30 PM
tightwoods's Avatar
HondaMechanic!
I'd like you to send me that as a PDF. I tried sending you a PM but the text screen doesn't show.
tightwoods
Old Oct 16, 2006 | 09:34 PM
none
Old Oct 16, 2006 | 10:12 PM
tightwoods's Avatar
email to: cowdancr@npacc.net
The machine is a 1987 350 Fourtrax. I think the wiring diagram will be enough to start with for right now. I am repairing it for a friend of a friend. It's been to several shops, they supposedly put some new electrical parts in, and it still has no spark. I just installed a new battery and have begun the troubleshooting process. Maybe you have some resistance specs for the basic electrical components? Thanks a bunch.
tightwoods
Old Oct 16, 2006 | 11:14 PM
none
Old Oct 18, 2006 | 06:55 PM
tightwoods's Avatar
1987 TRX 350D (Foreman) Cranking Speed Output Voltages
At cranking speed with the spark plug removed what voltages should I be reading for:
1. The pulse generator output (blue/yellow wire)?
2. The CDI output to the primary (black/yellow wire) of the ignition coil?
The other meter lead is grounded to frame. Thanks!
tightwoods
Old Apr 10, 2007 | 12:58 AM
bkklbudo's Avatar
Could I get the wiring diagram for 1986 fourtrax 350? I am working on one for my son that has not been running in a few years? First I had a fuel pump problem. It ran for about 1\2 hour now it doesn't have spark. Any help or other tests that I might check would be greatly apppreciated!
