LAKOTA VALVES PLEASE HELP!!!!
Old Oct 6, 2006 | 06:35 PM
tamiyacrawler's Avatar
Default LAKOTA VALVES PLEASE HELP!!!!
Does ANYONE own a lokato repair manual or know how to adjust the valves? What should the spacing be? I need info bad.
Old Oct 6, 2006 | 08:06 PM
holeshotz8436's Avatar
.004 intake .006 exhaust
Old Oct 6, 2006 | 08:07 PM
You need to set the piston at top dead center stroke and take off the 2 valve cover caps and stick a feeler guage in the gap to check for the correct spacing.
Old Oct 6, 2006 | 08:46 PM
Ok so The valve caps are on the engine head, under the gas tank, right? Ok, so after I remove the front fenders, tank, and valve cover, and check the valves how do I go about adjusting them?
Old Oct 6, 2006 | 10:59 PM
Ok I just watched a video and saw everything pretty much...you need to change shims to adjust them. Removing the shims looks tricky. The vid was boring, but it sure beats buying a repair manual!
Old Oct 6, 2006 | 11:00 PM
Oh, by the way, are those measurements american or metric?
Old Oct 7, 2006 | 01:23 PM
86250rrider's Avatar
please spend the $15 and get a repair manual. that way your will be able to handle many jobs without asking for step by step info on forums such as this . im not being rude..i buy manuals for all vehicles i own.
Old Oct 7, 2006 | 08:49 PM
The reason why I don't want a manual is because I can do everything on the bike accept for internal engine repair so in my opinion it's a waste. If you find a 15 dollar repair manual you tell me. Cheapest I found so far was 25 dollars.
Old Oct 25, 2006 | 10:27 PM
Baseballroxmasox's Avatar
Where did you find that online video?
Old Oct 26, 2006 | 09:12 PM
It was at google for a two cylinder engine with spacers so it was pretty much useless when I had the engine apart lol. I was amazed at how simple it really was. I set them with feeler guages now.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
