Dont oil 800/650 air filters?
Old Oct 11, 2006 | 10:26 PM
raidermike67's Avatar
Default Dont oil 800/650 air filters?
Just dropped my 800 off for it's first service and the service guy told me not to oil my air filter. He said it already has three layers of protection and that he's found some Outlanders were sending a false "check engine light" reading and in each case he's found dirty diodes(sorry, don't remember exactly which one) with oil residue on them dripping down from the air cleaners and that BRP told him it was not necessary to oil these air filters because of their design.
Has anyone else heard of this?
I strongly suggest everyone get this first service done, he could tell right away I had a valve rattling, I told him it sounded a bit loud but these things make SO many strange noises it's hard to tell.
I also got a new lid for the front, one that inserts into the plastic like the models through 04 so it will look better then those damn zip ties.
Old Oct 11, 2006 | 10:30 PM
BBR650's Avatar
Is always changing bikes.
you are only supposed to lightly oil the foam filter element with foam filter oil(ex. uni oil).
Old Oct 11, 2006 | 10:40 PM
Is that different then any other type of air filter oil? What about old fashioned WD40?
Old Oct 11, 2006 | 10:43 PM
BBR650's Avatar
yes the foam filter oil is thinner and doesnt soak the filter.
Old Oct 12, 2006 | 02:20 AM
kawiyowee's Avatar
Mike I can't imagine what those guys were doing that owned the bikes the tech was talking about.
Foam filters need tack oil, 'tacky' or 'sticky', to work right. Twin-Air sells the filters and the tack oil. That's what I finally got after using the Twin-Air tack oil on the BRP filter for awhile. The tack oil is sprayed onto the BRP green foam, squeezed all through it, then excess is squeezed out onto paper towels. It's easy to do.
I just got the Twin-Air filter cause it's all foam, it's meant to be tacked just like the green BRP foam filter, and it let's more air through. Also I'm going to get the richer program for the ecu, more gas from the efi's, cause I had a lot of stalling at high altitude last ride from extra air coming thru the filter, more stalling than before the Twin-Air filter.
Old Oct 12, 2006 | 02:23 AM
BBR650's Avatar
see my outty 650 is too rich...like on the accelerator side, cant get it tuned out or do anything about it, well i guess i could buy a slip on.
Old Oct 12, 2006 | 02:30 AM
kawiyowee's Avatar
A K&N or a Twin-Air? The Twin-Air should lean it out, it did mine, died at every stop above 11,000 feet, just annoying, cause it started right back up and ran good. Kind of like cold weather starts, have to start it 3 or 4 times now with the new filter, rather than just once or twice.
Old Oct 12, 2006 | 02:35 AM
BBR650's Avatar
worse still on stock filter lightly oiled.
Old Oct 13, 2006 | 01:07 AM
kawiyowee's Avatar
Maybe it would help answer the filter question if you rode it on asphalt, no dust, no filter?
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
