oil ratio for a banshee???
Old Oct 12, 2006 | 01:09 AM
jolivares80's Avatar
Default oil ratio for a banshee???
I'm curently using Castol 927 premix oil at 40:1, how high can I go before I need to worry about any damage on the engine? Is this true, the higher you go on your ratio the faster your top end will go out? I usually ride the dune and do some dragging, what ratio should I use to get max horse power with out doing any damage?
Thanks
Old Oct 12, 2006 | 01:49 AM
JLsparky7's Avatar
I run 40:1 as well as most of the people i know. Some guys on banshee HQ run the 100:1 amsoil at 80:1 but i would not reccomend it. You could get away with 50:1 with castrol but it will wear your engine a little more. Yes is does VERY SLIGHTLY increase your top end, im talking like .5mph. Remember changing your mix ratio means changing your jetting. Stick with 40:1 and get some upgrades. Welcome to the forums.
Old Oct 12, 2006 | 02:40 AM
kawiking's Avatar
i run 40:1 klotz- thats as high as im going to go. to many mods to try and get a couple of ponies from your gas mixure.
Old Oct 12, 2006 | 01:45 PM
oldturtle's Avatar
edit-delete
Old Oct 12, 2006 | 02:30 PM
DriverDoyle's Avatar
I also us Castol927 im running 32.1..But im running 101 fuel too..
Old Oct 12, 2006 | 03:58 PM
kawiking's Avatar
YOUR RUNNING 101 FUEL ON A STOCK MOTOR!!!! why are you doing that mr. shrader?????? sounds like your just throwing money away. i run 93 on my stock motor and it runs fine.
Old Oct 13, 2006 | 12:13 AM
Who said its ALL stock?
[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Oct 13, 2006 | 02:42 AM
ThrashAndCrash's Avatar
Who said its stock?
I was wondering where he got the "stock" idea from too..[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 13, 2006 | 03:16 AM
kawiking's Avatar
so... the truth comes out. i know theres more stuff on there other then some drag pipes.hmm.... what are you running 170-190 compression????? well.... mines missing half the bolts !!! so.. i say there's about 5 pounds there.
Old Oct 13, 2006 | 08:56 AM
2STROKEFUMES's Avatar
I use Yamalube at 32:1 its safe I never have to worry if Im getting proper lubrication. There are better oils out there tested at 100:1 and alot of people run that at 80:1 but I would never do that unless I had a bike strictly for drag racing and I planed on changing the rings every few months.
