BF 750i engine brake
Old Oct 13, 2006 | 06:29 PM
Formula1's Avatar
Default BF 750i engine brake
Just wondering if the engine brake is suppose to kinda grab and let go as you are descending a hill. My Kodiak was a constant brake feeling and I am not use to this one. Like I said, it feels as if it engages then disengages. Seems to be it should be engaged all the time. Thanks
Old Oct 13, 2006 | 06:34 PM
ATVHades's Avatar
It depends on the hill steep. It is normal for it to grab and let go lightly...if you just manage your throttle you can work around it.
Old Oct 13, 2006 | 07:24 PM
Hayashi's Avatar
Yes, it is normal for Kawis in certain condition.
The Kawi's engine brake system is different from Yami's, mainly because Yami uses a secondary clutch (centrifugal) on their tranny on their CVT quads. If you open up the CVT cover, the Yami's belt is always engaged between the drive converter sheaves and the Kawi's belt is loose between there (so that the engine doesn't stall). The Kawi's engine brake system prevents the engine from stalling when the quad slows down rapidly by releasing the engine brake forks from the ON position (pressing against the drive converter) to the OFF position (away from the converter)when the quad speed drops below 2 mph AND the deceleration of the quad is greater than a rate of 0.4G within an interval of 10 miliseconds. The above 2 conditions must be met. All this function is perfomred by Control unit which receives voltage signals from speedo sensor, fwd/rev sensor, EBC actuator potentiometer, etc. If any of the above things goes wrong, you will see 2/4WD flashing on your dashmeter.
Old Oct 13, 2006 | 10:39 PM
grizzkiller's Avatar
ok, hayashi, how do you know all of this?lol, are you a mechanic, read the manual, the designing engineer, or did you like do a vulcan mind meld thingy with your kawis? lol. whatever the answer, we all appreciate your help and wealth of knowledge!!!
oh, yeah, the touch & go KEBC is the way it is! as hayashi so eliquently stated!!
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
timster911
Jul 13, 2015 01:57 PM
MNatv89
Jul 7, 2015 11:36 AM
