bearing carrier interchange
Old Oct 14, 2006 | 02:43 PM
dan68rs's Avatar
Default bearing carrier interchange
Does anyone know if the banshee bearing carrier will interchange with the warrior? or any others that may work on the warrior. thanks
Old Oct 14, 2006 | 03:58 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
as far as i know they aren't i think the banshee carrior is just slightly bigger
Old Oct 16, 2006 | 02:22 PM
dan68rs's Avatar
so you could use it you just have to use the banshee axle too.
Old Oct 16, 2006 | 07:33 PM
recon99's Avatar
Well, the carrier would bolt on, but with the banshee axle you have the possibility that the sprockets might not line up perfectly. If your front and rear sprockets are off center, you'll have big problems.
But I must ask, why would you want to put a banshee carrier on a warrior in the first place?
Old Oct 16, 2006 | 07:34 PM
Boomer2's Avatar
q post 03 blaster will take a banshee bearing carrier no prob. Pre o3 you will have to buy a banshee brake caliper and master cylinder, plus you will have to make a spacer so the axle won't be offset.
Old Oct 17, 2006 | 11:44 AM
dan68rs's Avatar
I was just looking for a carrier for my warrior, and compairing my banshee to my warrior they look the same. So looking on ebay I was just wondering if I could look for a banshee one too or just the warrior. seems like the banshee ones are cheeper.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
