Diaphragm / Coasting Enrichener question
Old Oct 14, 2006 | 06:10 PM
CrazyWhiteDude's Avatar
Default Diaphragm / Coasting Enrichener question
On a warrior (like 96'). How will your quad run if your diaphragm is broken. Yamaha repair book calls it a coasting enrichener. I still can't figure out what is wrong with my warrior.
Old Oct 14, 2006 | 09:07 PM
bombrider04's Avatar
if it is torn your quad will pretty much run like cr@p it would be like if you were to pierce your lung would you be able to breathe so its the same idea for the diaphragm
Old Oct 14, 2006 | 09:09 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
diaphram as in the intake boot? i am not sure what you are trying to say here
Old Oct 14, 2006 | 09:10 PM
its in the carburator it could also be called a bladder its at the top of the carb on my ds650 its connected to the needle and slide
Old Oct 14, 2006 | 09:12 PM
Speedy2222's Avatar
i am still confused... lol and i've been through my carb so many times too
Old Oct 14, 2006 | 09:16 PM
on the warrior I just looked it up its number 19 its to the left on the picture on my ds the setup for the carb is a little different but its the same idea
http://www.ronniesmailorder.com/fich...=167&year=2004
Old Oct 14, 2006 | 09:17 PM
Speedy2222's Avatar
oo that..
Old Oct 16, 2006 | 12:09 AM
Are you sure that it functions the same. Because I have a DS too and it seems different.
Old Oct 16, 2006 | 06:34 PM
I looked it up and the diaphragm is on the side the ds one has the slide and needle and diaphragm all connected so its a little different then compared to the warrior well if they call it a coasting enrichener wouldn't that make the mixture more rich while not hitting the throttle hard atleast thats what I understand from the name that you mentioned but in the diagram I saw it said diaphragm take a look its one of my other listings when talking to speedy
Old Oct 20, 2006 | 05:36 PM
Thats what I was assuming it did also. It doesn't matter anymore because I found out that my problem is that the valves are leaking. That sucks
