Mod for EX that doesn't cost a thing????
Old Dec 7, 2000 | 12:22 AM
Aaron10's Avatar
I hear if you always run on reserve that the gas gets harder and faster suckesion and gives a little bit more power. Any truth? Can it hurt anything by doing this?
Old Dec 7, 2000 | 01:11 AM
Stroke9's Avatar
No way...
Old Dec 7, 2000 | 01:17 AM
rhubler's Avatar
Running on reserve all the time almost guarntees you will be walking for gas one day. your carb has an accelator pump on it, so I think you would have consistant presure no matter which position you run the tank valve except the off position.
Old Dec 7, 2000 | 07:14 AM
derekhonda's Avatar
If you are looking for a mod that doesn't cost anything, take off you airbox lid.
Old Dec 7, 2000 | 12:31 PM
RoostKing's Avatar
Make sure your throttle cable is adjusted properly. It has been said that as much as 30% increase in power can be obtained from the prpoer throttl eadjustment. I dont know if that is true on the new models though!
RoostKing...
Old Dec 7, 2000 | 12:51 PM
Aaron10's Avatar
How would I check for correct throttle cable adjustment?
Old Dec 7, 2000 | 02:09 PM
DoughBoyRacer's Avatar
I took almost 1/2 inch of slop out of my throttle cable. It let me give it more gas = more speed.
Brian
Old Dec 7, 2000 | 05:39 PM
Motorhead's Avatar
Your thumb throttle should have about 3/8" of free play. If it has significantly more (>1/2"), you're probly not getting WOT at full throttle. You can adjust it by pulling the boot on the throttle cable back and screw the cable end in or out.
Old Dec 7, 2000 | 05:46 PM
sAyIt_fmf's Avatar
Do not pull off your airbox lid unless you want to rejet.
It will run lean.
Old Dec 7, 2000 | 09:01 PM
HondaLuvr303's Avatar
I sometimes take the airbox lid off, but never any jetting probs.
