Warroir Carburetor
Old Oct 16, 2006 | 01:44 PM
oneflag's Avatar
Default Warroir Carburetor
I have a 1997 Warrior it starts and runs good. But recently it started cutting out.
It only does it when I have the throttle wide open. If I'm really on the gas, right before I feel its time to shift it starts cutting out and falls on its face. It's almost like it's got a rev. limiter on it. Any ideas???
Old Oct 16, 2006 | 01:49 PM
bombrider04's Avatar
Well my guess would be that you are either running out of gas or are already...the choke is still on or you jets are starting to get clogged up so it may be time for a cleaning.
Old Oct 16, 2006 | 07:29 PM
recon99's Avatar
You probably need to clean out the carb or maybe adjust the floats. Also, how clean is your air filter. A clogged air filter can cause unexpected problems sometimes.
Old Oct 16, 2006 | 09:08 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
well if u want i could call ya( got your # right here ) and tal kya throguh it.. i just had this same identicle problem.. i know how to fix it
Old Oct 16, 2006 | 09:27 PM
GlennJ's Avatar
I'd start with checking the air filter and cleaning out the carb bowl. I had a similar issue on my machine...turned out to be some crud in the bowl.
Ask the Editor
Sep 14, 2015 08:57 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
WesTech
11
Aug 11, 2015 07:55 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
