Help with SunL90 axle bearings
Old Oct 16, 2006 | 11:23 PM
GDITheman's Avatar
Default Help with SunL90 axle bearings
My son's axle bearings/bushing wore out on the sprocket side of the axle. I need to know if there is a bearing in the axle housing an if so, where can I get new bearings? If not, and it's just a bushing, where can I get that?
Any installation tips? The rubber bushing is so worn out that it popped out of the axle housing and the axle is flopping around in the housing cause the chain to jump off the sprockets.
Any help is appreciated.
Old Oct 17, 2006 | 02:41 AM
smb05's Avatar
Your best bet is to pull the axle apart. There will most likely be a combination of bearings, bushings, and seals that will need to be replaced. The bearings and seals should have a combination of numbers and letters on them to help you identify the part. This will help in replacing the parts if you are going to try and find the parts on your own. Or your best bet is to give Raceway a call and they will supply you with the parts you need.
SB.
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
jbrewster94
Sep 23, 2015 04:16 PM
1000gade
Sep 9, 2015 04:41 PM
