4WD light flashing 6 times (2004 Foreman S)
Old Oct 19, 2006 | 07:09 PM
casey133's Avatar
Default 4WD light flashing 6 times (2004 Foreman S)
Hi all,
I have a 2004 Foreman 450s and sometimes (not all the time) when I put it in 4WD and go over some rough gound such as rocks and come back to level ground, I come to a complete stop and put it back in 2WD and I can see the 4WD light will flash six times in a row, wait about three seconds and will flash another six times. I will keep doing it even if I switch it in and out of 4WD.
The next day when i start it up everything is fine and no flashing light.
Any ideas?
Thanks for any input.
Old Oct 19, 2006 | 09:13 PM
cluby's Avatar
possible one of speed senors, there are 2 of them.
Old Oct 19, 2006 | 09:34 PM
casey133's Avatar
I will look into that but for now, are those easy/affordable to fix?
Thanks for the help again!
Old Oct 20, 2006 | 09:18 AM
cluby's Avatar
not to bad to replaced but about 70 bucks, When you go into your dealer tell them too look up what a code 6 is I will look myself today when I am at work
Old Oct 20, 2006 | 02:14 PM
JeffinTD's Avatar
On my 05 anyway, 2 is front speed sensor, 3 is rear, 4 is system voltage, and 5 is front clutch system. It doesn't list a 6...
Old Oct 20, 2006 | 03:01 PM
casey133's Avatar
I would be very thankful.
Old Oct 21, 2006 | 02:01 AM
hondabuster's Avatar
6 flashes points to an alternator related issue. most likely its a loose or water filled connector. Check the connections coming out of the motor for the stator and at the front fcc unit.
Hows the battery doing? Hows the connections at the battery...clean and tight and non oxidized?
Old Oct 21, 2006 | 07:34 AM
HondaMechanic's Avatar
none
Old Oct 21, 2006 | 09:42 AM
cluby's Avatar
code 6 is the engagement coil for the 4x4, very expensive to fix,
Does it is have 4x4?
Old Oct 21, 2006 | 12:59 PM
casey133's Avatar
Can this type of info be found in a service manual? I just ordered one and hope to find directions on how to fix the problem.
I will check the battery connections today and will see if they can be cleaned, anyone have any other steps that should be taken before I start buying parts?
cluby, it still has 4x4 yes.
