Plow on kodiak 450/grizzly 450
I own a 2007 grizzly 450, i have the warn winch 2.5 installed what do i need to do to put a plow on my quad, can i use the same winch or do i need a different one that moves up and down ? can i use the same wiring if i need a different winch ?
yammi sells a warn plow that comes with everthing you will need...your winch cable connects to the plow...so no problem there
any complete plow setup will work....I got a warn off ebay.....
There is a pully on the yamaha/warm plow, you hook up your winch cable to that and your good to go. Or you could buy the manual arm (which IMO is faster). The kodiak/grizz should do fine. I had my bruin (that is only a 350) plow my driveway all last winter, had no problems at all. I plowed with my stock tires on, no diff lock. Sure beat shoveling. I can probably park 20 cars in the driveway ) so its not small. Your quad should be able to do it fine unless you live on a mountain and your driveway is in terrible shape winding down and eroded (my buddies driveway comes to mind..lol) .
thanks alot guys, i have a plow truck for the larger drive ways, i will use this one for the neighborhood, everyone has relatively mediocre sized flat driveways and it would be alot easier to manuever an atv in them.
Like was said before, any plow set-up will work with your winch. I have an 05 Kodiak 450 with a warn winch and a Moose 60 inch county plow. The set-up works great. You'll be fine with your 450.
kampswas
Sep 23, 2015 05:05 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
