Do you have a SUNL Utility ATV?
Old Oct 24, 2006 | 12:49 PM
RanchBuggy's Avatar
Default Can Anyone
Looking for anyone who has a SUNL utility and knows about some of the problems I'm experiencing with mine. I'm thinking if we get together, we can help each other out without having to take to the shop. Also this may include the Roketa which I think is made by the same place from China.
Thanks[img]i/expressions/face-icon-small-cool.gif[/img]
Old Oct 25, 2006 | 07:28 AM
mykool61679's Avatar
Default Do you have a SUNL Utility ATV?
my boy has one!!
Old Oct 26, 2006 | 11:49 PM
RanchBuggy's Avatar
Has he had any problems? Mine has had trouble starting in the cold weather recently. It doesn't have a choke and wanted to know if there was a trick to getting it started easier?
Thanks
Old Oct 27, 2006 | 10:31 AM
problem with the battery, thats about it! his has a choke on it. i know they say you have to adjust the valves. how long have you had it?
Old Oct 27, 2006 | 11:15 AM
RanchBuggy's Avatar
About three months. Only problem with battery is the charger doesn't work as good as putting a 12 volt battery charger on it. On cold mornings, I have to really have it charged because it will run down when I keep trying to turn it over trying to start it. I adjusted the idle speed but not sure how to adjust valves? Can't believe mine doesn't have a choke on it? If you can give me any insight on how to adjust it, I'd really appreciate the help.
Old Oct 27, 2006 | 11:56 PM
hoytultratec's Avatar
you need a new battery,walmart.
go to kids and other quad forum to find out how to adjust valves.
it probably has a electric, automatic choke, these are cold blooded machines, might have to rejet.
you can learn alot more on kids quad forum.
Old Oct 28, 2006 | 01:27 AM
RanchBuggy's Avatar
Thanks, I check that out and see if I can learn something. Going to try and get another battery from the dealer. Only had the machine for 3 months.
Old Oct 28, 2006 | 10:30 AM
spend the 30 or 40bucks get a good battery especially if it gets cold where you live. these ones that come with them are bad. hope this helps
Old Oct 28, 2006 | 10:33 AM
RanchBuggy's Avatar
I was heading to WallyMart today for that...Thanks for earlier suggestion
Old Oct 28, 2006 | 10:40 AM
buying a good battery will save a little head ache![img]i/expressions/face-icon-small-smile.gif[/img]
