05 raptor 660 rev limiter kicking in AGAIN!!!
Old Oct 25, 2006 | 11:27 PM
velocyraptor's Avatar
Default rev limiter kicks in on 05 raptor 660
my rev limiter started to kick in, it kicks in at 1/2 throttle. i tried grounding the plug with the green/white cable thats below the shifter. i unscrewed the little cable next to the green/white cable and thats didnt work either. i took off the sensor on the clutch lever and that didnt work either. i conected both cables of that sensor and nothing . i tried grounding each one by itself and then i tried grounding both at the same time. i removed the sensor on the front brake lever and nothing. is there another sensor i dont know of or do have any idea what i could do to fix it?
Old Oct 25, 2006 | 11:42 PM
chip700r's Avatar
my buddy had a problem with his rev lmtr kicking in on a 03 660,his cdi box was going bad...If u know anyone with another 660 u can switch cdi boxs in a few minutes to see if it fixes it
Old Oct 25, 2006 | 11:54 PM
i have another one here, i'll change them tomorrow
Old Oct 25, 2006 | 11:58 PM
chip700r's Avatar
is yours doing the same thing every time??his sometimes wouldnt let you rev at all,sometimes would come in at 1\2 throttle,,,,then would work fine for 20 minutes or so of riding then start again
Old Oct 26, 2006 | 12:11 AM
it doesnt go away
Old Oct 26, 2006 | 12:41 AM
chip700r's Avatar
not sure if it will fix yours or not,,,,may be worth a try though...good luck....at least u have another one ,those boxes arent cheap
Old Oct 26, 2006 | 01:39 AM
i meant another raptor, i hope it works i want to go riding this weekend
Old Oct 26, 2006 | 12:15 PM
orion8419's Avatar
does the 700 lower the rev limit when your in neutral? i notice that when i rev it in neutral it dosnt seem to go past half. dosnt seem to do it when im in gear
Old Nov 13, 2006 | 01:05 AM
i really need your help, i took the raptor out for a spin outside the shop the day i went to pick it up and it was fine, then i was installing my axle and i needed a clip so i wasnt able to ride, so i got the clip and installed it and went for a ride and i am having the same problem. i would accelerate and it would die and come back like if was not jetted correctly but it is. what else can it be besides the clutch sensor? could it be the stator? i was troubleshooting and i turned on the light to see if the intensity of the light would drop but it wouldnt so im guessing the stator is fine. WHAT CAN IT BE?!!!!!!!!!
i already exchanged rev box, cdi, coil and selenoid with another raptor, cleaned and checked the spark plug and checked the carbs for any dirt but it still has that problem
Old Jul 19, 2014 | 06:00 PM
con.way's Avatar
Did you ever find the problem? Heard it might be improper power to the coil
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
