Do away with raptor reverse rev limit
Old Oct 26, 2006 | 12:32 AM
bluedino's Avatar
Default Do away with raptor reverse rev limit
I found on an 03 Raptor 660 that If you hold the clutch in slightly the rev limiter in reverse didnt function. So simply by removing the clutch sensor switch on the handle bar, will do away with the rev limiter. Only down side, quad will start weather the clutch is pulled or not since the sensor switch is gone. Curious if this works on other year models.
Old Oct 26, 2006 | 07:39 AM
paintballbanshee's Avatar
Hey what handle sensor?? do you have to do anything with it? did you do and it can you explain to me a little more detail? thank you
Old Oct 26, 2006 | 09:21 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
should work on any quad with a parking brake
Old Oct 26, 2006 | 12:03 PM
SickSixtyRider's Avatar
I removed my rev rev limiter by bypassing the switch under the shift lever.
Old Nov 5, 2006 | 03:33 PM
bluedino's Avatar
the switch that hits the clutch handle. Its the switch that wont let you start the bike without the clutch pulled in. just take it out of the mount where it dosent hit the clutch lever any more and it should work. Hope this helps you out some.
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
