YFZ 450 JETTING
I've got a 2006 YFZ 450.
*Pro flow with k&n
*k&n air box lid
*full yosh exhaust
*gytr jet kit
*tusk fuel mixture screw.
I am riding at 3500 ft where should I start the jetting? Any help would be great. Thanks.
*Pro flow with k&n
*k&n air box lid
*full yosh exhaust
*gytr jet kit
The jet kit is OK. I just buy the Keihein jets that I need though. I'm running a 170 main but don't have an intake. I am at 500ft. BTW, you need to jet bigger in the winter, as colder air is denser and has more oxygen, therefor you need more fuel. But then again, you are a fair bit higher in elevation than I am.
The jets are keihin jets in the gytr kit. I understand jetting and have done it many times. I bougth the dynojet kit it was crap. The quad ran good but it sputtered on the top end. I know that it was rich on the main jet but I went from from the 165 dynojet down to 140 one at a time. It was 8 jets in all. It happened in first second and thrid but not in forth and fifth after dropping a few jets. I tried dropping the needle it still sputted in the first 3 gears on top end. I put in a 165 keihin still sputtered. I tried going back to the factory needle riseing it up from 3 to 4 slot it would make it richer I know but with the mods I figured it should be about rigth.I am going jetting tomorrow I hope I can get some where close to start. I do not think it was the rev limitter it has a tack and reved a couple of grand higher in fourth and fifth. Thanks.
Heres even a better link with more info on jetting for altitude.
http://www.thumperfaq.com/jetting.htm
Hope this helps!
Hope this helps!
