DS 650 Rear shock Spring Replacement. ?????
Old Oct 28, 2006 | 12:55 PM
Mrneg9's Avatar
Default DS 650 Rear shock Spring Replacement. ?????
Hey guys. Im 280lbs and have recently been jumping my 04 DS 650 Baja. I read the manual on how to set up the rear shock. It ends up I have the collars on the rear shock as far as they will adjust. I have been hitting the jumps and bottoming the back of the quad out. I would like to replace the rear spring with some thing stiffer. Has any one done this and where do I get the spring? I dont want to buy one and it not make a difference. Thanks again for the info. derek
Old Oct 28, 2006 | 01:06 PM
FatHolly's Avatar
Bottoming out has nothing to do with your spring at your weight. You need to adjust your compression firmer, that is the adjuster on the rezy. Try a couple clicks at a time and you will be fine. The spring adjustments are only for ride height. The DS has a very nice rear shock, with both compression and rebound adjustments, I bet with some tinkering you will get it dailed in very nicely.
Old Oct 28, 2006 | 01:53 PM
bombrider04's Avatar
yep look on the resi and there is a slot for a reg screwdriver and I believe if you turn the screw clockwise it will make it softer and turning it counterclockwise it will make the suspension harder
Old Oct 28, 2006 | 02:28 PM
1882's Avatar
Runs a Full 730 Race Build!
It's actually the opposite way turning the clickers....
Old Oct 28, 2006 | 02:30 PM
lol thanks I wasn't sure I was thinking of how it is on my r
Old Oct 28, 2006 | 02:58 PM
Mrneg9's Avatar
Thanks guys will do exactly that. D
Old Oct 28, 2006 | 08:54 PM
MrMeaner's Avatar
Make sure the gas hasnt leaked down
Old Oct 29, 2006 | 08:19 PM
ERBEDS650's Avatar
At over 250 lbs a rider should get the rear shock revalved and a spring to there riders weight, I sent mine to TCS and was a night and day difference!!!
Hey Holly JUst got back From Glamis !!!!! was Great. many coors gave ther all in the battle of looking for topless females this weekend!
Old Oct 29, 2006 | 10:21 PM
[img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 30, 2006 | 11:37 AM
Mrneg9's Avatar
Who is TCS and how can I reach them ? Thanks.
