2007 Eton Viper 70
Old Nov 6, 2006 | 11:53 PM
R450Pilot's Avatar
Default 2007 Eton Viper 70
I'm considering getting my son an Eton Viper 70 for his first quad. It looks like for 2007 Eton is going with a dual A-arm setup on their Vipers. Does anyone have one or have then seen one? I tried finding any pictures of one, but haven't seen any yet, so post any pictures if you have any.
Old Nov 17, 2006 | 06:37 PM
R450Pilot's Avatar
I starting to think the 2007's aren't out yet. It is hard to tell because my local dealer is behind on all of their quads.
Old Nov 17, 2006 | 08:39 PM
superbombman's Avatar
the new 70cc does not have double a-arm's up frt.
Old Nov 17, 2006 | 08:47 PM
Vulcan700's Avatar
http://www.speedcityscooters.com/scooteton_RX4-70.html
That is a link to some pictures and spec [img]i/expressions/face-icon-small-happy.gif[/img]
Engine Air cooled 68.0cc 2 stroke engine
Drive Train Automatic single speed transmission.
Suspension Fully independent front A-Arm and adjustable rear swing arm
Brakes Front dual mechanical drum brake and Rear hydraulic disc brake
Max Rider Weight 190lbs / 68.2kg
Chassis 36.1" Wheel base and over all dimensions of 57.9"L x 33.5"W x 32.7"H. 238.0lbs dry weight.
Safety Safety tether switch and remote control shut-off switch (optional). Meets CPSC and ANSI Y-6 safety standards for 6 year old and up. With fully enclosed engine compartment and footrest areas.
They also have the 4 stroke
http://www.bushmotorsports.com/VIPER70.html
Second link
Old Nov 18, 2006 | 11:29 AM
R450Pilot's Avatar
Where did you get that information from? Have you seen one yet?
I ask because the Etonamerica.com site states this.
Specifications - 2007 Four Stroke RX4-70
* Air cooled 69.3cc 4-stroke engine
* Automatic single speed transmission
* Dual adjustable front A-Arm and adjustable rear swing arm suspension
* Front dual mechanical drum brake and rear hydraulic disc brake
* 36.1" Wheel base and overall dimensions of 58.3"L x 33.5"W x 33.9"H.
* 247 lbs dry weight.
* Meets CPSC and ANSI safety standards for 6 year old and up. With fully enclosed engine compartment and footrest areas.
* Max rider weight: 190lbs / 68.2kg
Etonamerica.com
Vulcan 700, thanks for the information you posted, but I think that is for the 2006's.
Old Nov 18, 2006 | 04:21 PM
oldyeller's Avatar
It can be a little confusing when they say dual A-arm ..I believe they just mean two all together(on each side) as opposed to some of the other models with a swingarm type front suspension (yamaha etc)..The only ones I have seen listed with dual on each side have been the 4 stroke 90cc models
Old Nov 18, 2006 | 05:41 PM
R450Pilot's Avatar
old yeller, I think you might be right. I still haven't seen an 07 and was hoping it was dual A-arms on each side.
Old Nov 18, 2006 | 08:16 PM
I'am a dealer for eton and there 70cc 07 models are not double a-arm but are for sure 4 stroke. If i was you and you want the double a-arm then go with the 90r 4stroke it's just alittle bigger not real noticable and has the same safety features imo.
flyin-lowe
Dec 1, 2017 03:18 AM
Sep 23, 2015 06:23 AM
Minimod
Sep 10, 2015 09:20 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
