Need Motor work on 2003 cannondale fx440
Old Nov 9, 2006 | 12:38 AM
cannondale2001's Avatar
Default Need Motor work on 2003 cannondale fx440
hey all i got a fx440 engine that is completly dissasembled and i need someone toput it all back together. i live in Seattle, Washington so it would be more convinient for someone to do it that lives around here.
Old Nov 9, 2006 | 11:52 PM
Sandgod's Avatar
Send it to www.blackwidowatv.com These engines need to be looked at carefully. These guys have rebuilt hundreds of motors.. Chances are you will have some worn parts that must be replaced.. This can only be done by somebody who knows these engines inside and out.. Trust me on this. Your quad will run for years w/ no engine issues if you send it to them, because your everyday wrench doesn't know the little tricks to rebuild these engines to last. Your motor should be back to you in two weeks from the day you ship it..
Old Nov 11, 2006 | 01:51 AM
bombrider04's Avatar
Sandgod do they do the updates to the engine automatically the atk updates I mean so the engine doesn't handgrenade...because if they do the updates which I am sure they do then I would have them rebuild the entire engine for you cannondale 2001
Old Nov 11, 2006 | 02:23 AM
Sandgod's Avatar
The wrench at Black Widow worked at ATK for over two years doing nothing other then rebuilding these motors. Black Widow is only 25 miles from ATK. Both places are close to my house. Cord is the wrench at BW.. He knows these engines very well. He is a perfectionist and knows exactly what to look for. These motors are different. They don't have case haves to split. The tranny slides out out w/o having to pull the head off. The jug is part of the case and some other different ideas.. Some items wear out quickly some don't.. Assembly problems were most of the issues w C-Dale. ATK does all the correct upgrades except one of the most important.. The big end rod bearing needs to be changed to a Z400 bearing and ATK won't do it. They are ignorant as they say it's not needed.. They are dead wrong!!!! The Dale bearing was a good attempt, but it will fail.. The main bearing in only the FX400's was a bad design also in 01. It will fail also.. Cannondale actually corrected that in the 02 year..
Old Dec 4, 2006 | 02:57 PM
thedeatons's Avatar
My friend Chris rebuilds Dale motors, and has done 12 Dale engines throughout the years. He specializes in engines that arrive in buckets, needing a buildup from scratch. We are located in Sacramento, and currently have over 8 Dales among us. Black Widow is a great source for engine rebuilds, but if you would like someone a bit closer and a bit cheaper that can perform the same service, give us a call. We currently order all our parts from Black Widow, but our labor rate is cheaper, as we have another form of primary income. Chris currently has three engines on the bench in various states of rebuilding, and can accomodate more. 619-980-7268
Old Dec 14, 2006 | 09:23 PM
Thunder53's Avatar
Cord at BlackWidow has worked on alot of my dale parts and like Sandgod said he is a perfectionist any little thing he see that looks like it could be a problem he will let you know, great place I would recommend them anytime
Old Jan 8, 2007 | 09:59 PM
championmotorsports's Avatar
Hi, If you're still looking to get your motor reassembled we would be more than happy to do it for you. We use to have a Cannondale dealership and Scott knows his way around these motors, he gives a good deal too. If you're interested give us a call.
Old Oct 31, 2012 | 01:46 AM
Degrotis's Avatar
Default Does anyone still work on these Canondales
I have a 2001 FX400 engine not running. Wondering if it is even worth rebuilding or getting someone to rebuild it.
So thought i would ask if anyone does the rebuilds, I have rebuilt engines on quads before but I seen that that these engines require some special knowledge and experience with them.
Let me know if you know anyone that can do it, even better if you know someone in Canada but not a deal breaker.
Thanks
3quadbob
Sep 18, 2016 09:46 PM
Nelson
Jun 22, 2015 03:51 AM
JackOReilly
Dec 7, 1999 09:12 AM
