Scrambled Oil pump!!!
Old Nov 9, 2006 | 07:59 PM
eli98's Avatar
Default Scrambled Oil pump!!!
Hi there guys just pulled the engine apart on my 95 400 Scrambler. Originaly I thought i had bad crank bearings. Now it is apparant that the oil pump is in a million pieces. My question is, how much work is it to remove the oil pump. Should it feel as though the the pump is bolted in place? I pulled the gear off the crankshaft and the small plate in behind the pump gear. Don't have foggiest idea what to do next. Do I have to pull parts off elsewhere or does it slide out from behind the timing cover? I am thinking it might be jammed due to the internal problems. Help please.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
