1997 scrambler 400L secondary clutch
Old Nov 10, 2006 | 07:42 AM
FRANKIEZ's Avatar
Default 1997 scrambler 400L secondary clutch
I removed the primary and the secondary requires another size puller, the thread size is not 3/4 it is larger, any suggestions other than buying tool and when going back together any tricks with drive and driven clutch installation.
Old Nov 10, 2006 | 07:59 AM
ftwflh's Avatar
The secondary clutch shouldnt need a puller unless it is rusted to the shaft.Try spraying penitrating oil in the bolt hole and behind it and see if that helps.If it doesnt you will have to get a secondary puller.
Old Nov 10, 2006 | 09:36 AM
FRANKIEZ's Avatar
Thanks for the info, will try.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
