Rolled it over, now won't start!
Old Nov 14, 2006 | 10:57 PM
DitchDigger's Avatar
Default Rolled it over, now won't start!
I was out on a steep side hill in the snow, and barrel rolled my Xplorer 4x4 400 3 times before it stopped against a tree. It was on it's side for about 10-15 minutes. I got it back on the tires, and it fired up right away, but then died again. I tried changing the plug and it seems to be getting gas too. Could the float be stuck in the carb or something? When it does start up for a few seconds I have to choke it, but then it dies with or without the choke on. Any ideas?
Thanks
DD
Old Nov 15, 2006 | 12:05 AM
4wheelerfred's Avatar
take your carb apart and check it out
Old Nov 15, 2006 | 12:06 AM
rodknocker's Avatar
did you check the air filter for oil or gas it may have goten some on it while it was on its side
Old Nov 15, 2006 | 01:02 AM
Baseballroxmasox's Avatar
I can say that it is most definately your carb. The float just needs to be cleaned a little bit, and should be good to go. Give me an update on how everything goes? Thanks
MikeyBoyesq
Nov 27, 2020 02:44 PM
Shooterj2003
Jun 21, 2015 09:02 PM
Jbird4681
Jun 9, 2015 01:59 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
1000gade
May 27, 2015 12:37 PM
