400ex carberatour question
Old Nov 18, 2006 | 10:51 PM
dabrowat's Avatar
Default 400ex carberatour question
I have a quick question. I knowticed that theres fuel dripping from the carborator (Chamber set). Its not consant, but its also not suppose to drip. This started happening a few days ago. Haven't ridden it for about a month. I wonder if the screw loosened. I also knowticed a tube that isn't connected to anything. Its the black tube by the choke. Thanks for your help.
Old Nov 18, 2006 | 11:02 PM
dabrowat's Avatar
http://www.bikebandit.com/partsbandi..._id~380388.asp
Its the tube(#36) on the chart thats not connected to anything. Is that an air tube?
Old Nov 19, 2006 | 01:24 AM
hondabuster's Avatar
That hose is just a vent,
The hose that comes off the float bowl, is a vent and an over flow tube. If the float allows the float bowl to over fill, the excess will flow out that hose, and the screw can not shut that off. That float bowl screw only shuts the drain function.
Youve probably got some crud stuck inbetween the float needle and its seat, which is allowing the float chamber to over fill.
A simple thing to try...put the over flow tube in a can, open the drain screw, and allow gas to freely flow out the tube..then rap with a screw driver handle on the side of the carb. You might be able to dislodge whatever is hanging up the needle. If that doesnt do it, youll need to remove the float bowl and manually clean everything inside there.
Old Nov 19, 2006 | 01:21 PM
dabrowat's Avatar
Is the drain screw the big one on the bottom? So I unscrew it completely or until gas is coming out of the vent? Thanks.
Old Nov 19, 2006 | 02:52 PM
Its the flat slot screw, which is at the bottom of the float bowl. It only needs about 2 turns or so, its not necessary to remove it. Its kindof like a bleeder on a caliper.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
