97 300 express timing???
Old Nov 19, 2006 | 08:40 PM
ratman68's Avatar
Default 97 300 express timing???
had to rebuild my 300 , rod, crank bearings, piston ect. i put the stator back in and tightened down where the witness marks were. this thing seem to have alot of detination now. how can i ck and see if i am out of time or is there such a thing. help help help....
Old Nov 20, 2006 | 02:50 AM
ratman68's Avatar
ttt
Old Nov 20, 2006 | 02:11 PM
ratman68's Avatar
ttt
Old Nov 20, 2006 | 07:12 PM
ratman68's Avatar
anybody????????????
Old Nov 20, 2006 | 07:32 PM
cornbread2's Avatar
Most likely you problem is a lean fuel mixture instead of your timing.
When you rebuild the top end of a two stroke sometimes you have to play with the jetting.
Old Nov 21, 2006 | 11:43 AM
conig's Avatar
ditto definately check the jetting as well as sometimes the hash marks move a tad when tightening down the stator plate you may want to check it out.
Old Nov 23, 2006 | 11:03 AM
ratman68's Avatar
i took the cover and flywhell back off, i didn't see the pointer and the scribe on the stator the first couple of times it was apart but it is almost dead on. is this a factory mark? i pulled the spark plug and noticed it was only set at .011 and should be .028. also i deleted the oil injection on this thing because i roached two pistons in ten miles, would that have anything to do with this detination noise? if i was going to try and time it with alight how would i ck it? remember this thing has been aprt 3-4 times with me knowing about the scribe mark on the stator??
thanx for all inputs
Old Nov 24, 2006 | 01:11 AM
ratman68's Avatar
ttt
Old Nov 24, 2006 | 04:02 PM
ratman68's Avatar
ttt
Old Nov 27, 2006 | 02:29 PM
ratman68's Avatar
ttt
