Honda 4x4 CHOKE?????
Old Nov 20, 2006 | 10:07 PM
nlafu's Avatar
Default Honda 4x4 CHOKE?????
I have a 2003 Honda 350 Rancher, 4x4. Love the bike!!! The manual choke worked fine when new, but over the last couple months after pulling the choke out to start in cold weather, it "slips" back to the off position on it's own. Not always a big deal, but when out on a hunting weekend in the sub freezing mornings, you must stand with the bike and hold the choke on until the bike is warm enough to idle. Why my buddy is back inside the cabin (warm) while his bike warms up. I talked to a friend who owns a 05 Rancher and his bike has the same problem. Just wondering if anyone else has this problem and if it is an easy fix. Not a real major problem, but can be annoying. Thanks to all, HONDA RULES!!!!![img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 20, 2006 | 10:26 PM
HondaMechanic's Avatar
There is a plastic jam nut under the rubber boot .. .You need to tighten it a little with your fingers ..
Old Nov 20, 2006 | 11:01 PM
RancherATCrazy's Avatar
Both of mine do the same thing, I never really thought much about it. I will check that plastic jam nut now though. Thanks HondaMechanic.
Old Nov 21, 2006 | 12:22 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Do you know that it has a carb heater??? Turn the key on for a couple of minutes before you start it, and things may go easier.
Turn the idle up a little, that will help too.
My choke slips in as well. Never really considered it a problem though.
Old Nov 21, 2006 | 10:24 AM
ddrumman2004's Avatar
Mine does the same thing. Thanks hondamechanic!
Old Nov 22, 2006 | 09:45 AM
sHiNdIg's Avatar
Mine has been doing it since day one. I never got a chance to have a look at it.
I assume this nut is under the boot which is part of the assembly on the handlebars, not under the seat on the carb, correct?
Old Nov 22, 2006 | 07:25 PM
wirinfrenzy's Avatar
mine did the same thing until i tightened the jam nut under the plastic
Old Nov 23, 2006 | 12:16 PM
I tightened the plastic jam nut on the choke and it stays put. Thanks again.
Sure is nice to be able to pull the choke out and it stay put. The Bruin choke stays put as does the little 90 so why not the Rancher?
Old Nov 26, 2006 | 07:48 PM
nlafu's Avatar
Hey "Hondamechanic" thanks so much for the tip! Now my choke works like it did when the bike was new. Appreciate you sharing the knowledge!!
Old Dec 14, 2006 | 12:54 AM
alfama's Avatar
Thanks for the tip Honda Mechanic, the choke hasn't held its position in over two years.
WesTech
11
Aug 11, 2015 07:55 AM
binky79
Jul 30, 2015 06:37 PM
cornermike
Jul 30, 2015 06:37 AM
ghost civic
Jul 27, 2015 03:15 AM
timster911
Jul 13, 2015 01:57 PM
