oil drain plug
Old Nov 21, 2006 | 09:11 AM
HOSPORTSMAN's Avatar
Default oil drain plug
Can anyone tell me if there is a difference in the oil drain plug from a 03 sportsman 500 and and newer 500.
Thanks HOSPORTSMAN
Old Nov 21, 2006 | 09:23 AM
The problem I have is that my oil tank leaked on my sportsman since the first time I changed the oil. I came out
pretty hard from the factory. I torqued it to the factory spec. because of my fear of the plastic tank. It leaked a little so I held off on taking it to the dealer thinking maybe it was a bad gasket since I did not replace it. After leaving a pan under it for the last few years and adding oil when needed, I finally replaced the tank with a new one. But the new tank has a little plastic v coming down to the drain plug and my drain plug is to big around to fit. And yes I did replace the gasket with all the other oil changes, It is not the first oil change still. Thought someone could tell me if the drain plugs were now different.
Thanks HOSPORTSMAN
Shainasmash
May 8, 2017 06:38 PM
SDR-II
Sep 29, 2015 01:06 AM
Polaris5
Aug 29, 2015 09:11 PM
JohnnySplat
Aug 6, 2015 12:07 PM
momma's bike
Aug 6, 2015 09:49 AM
