Frustrated 2005 Grizzly
Old Nov 25, 2006 | 06:42 PM
rovergrizz's Avatar
Default Frustrated 2005 Grizzly
I have a 2005 Yamaha GRizzly.. Great condition.. 110 hours 660 miles.. Ridden or at least started for 5 minutes ince a week... Lately my grizz will just leak gas overnight.. If the gas selector is ON and it sits overnight like that there will be a huge puddle of gas in the morning. It comes out of the tube that comes out of the bottom of the CARB.. Any idea why it is doing this? What can I do to fix it and how? I just replaced all the gas with stabil in it.. Any advice is greatly appreciated.. Thank you Blake
Old Nov 25, 2006 | 06:44 PM
yamahalltheway's Avatar
the valve on bottom of bowl is bad! you can ether replace(recomended) or stick a bolt up in there which would be a cheap and dumb way to fix
Old Nov 25, 2006 | 06:49 PM
rovergrizz's Avatar
when you say the valve, are you refering to the screw located just above the drain tube? Or is the valve what the hose goes into? I really appreciate your help.. CARBS are my weak link.. you should have seen me try to tune dual carbs on my jet ski..It was not pretty
Old Nov 25, 2006 | 06:50 PM
rovergrizz's Avatar
I saw range rover in your little profile.. I have a Rover as well.. discovery
Old Nov 25, 2006 | 06:51 PM
yea what the tube goes into if you want to you can take the bowl to a parts place or go to powersportspro.com to get a new one. You can look at a diagram to find it NP
Old Nov 25, 2006 | 06:58 PM
rovergrizz's Avatar
one last question, what is the trick to getting the valve out? Plyers ??? or do i need to take the whole bowl off? thanks again
Old Nov 25, 2006 | 07:01 PM
sorry but i have never taken it out i just have heard that when it drips gas from there that the valve(also known as float) is bad
salixair
Nov 3, 2015 08:25 AM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Brandon400
Sep 5, 2015 08:44 PM
