Valve & Carburetor settings for Suzuki 125LT (1983)
Anyone have the specs for the settings for the valves and carburetor for a 1983 Suzuki 125LT?
I have changed the piston, rings, valves have been ground, rebuilt the carburetor, compression is good. Still am having problems getting full, even power. When throttling, engine will not rev evenly but surges, and then, not even at full power.
Any suggestions?
Any suggestions?
well bill i happent o have just bought the manual a month ago so ill help you out.for the carb :
Idle r/min.- 1550+_50 r/min.
fuel level- 4.5+_5.0 mm
float height- 25.8+_1.0mm
pilot screw- 1-3/4 turns out
do you need jet #'s or not?
the "+_" signs are those plus-over-minus signs i cant do on my comp.
Valves:
valve diameter- in-30mm
ex-26mm
valve lift- in-5.5mm
ex-5.5mm
valve clearance or tappet clearance (cold):
in & ex: .08-.13mm
valve guide to valve stem clearance:
in-.010-.037mm
ex-.03-.057mm
valve guide I.D.: in & ex-5.5-5.512mm
valve stem O.D.:in-5.475-5.490mm
ex-5.455-5.470mm
you need anyothers or is this enough?
just email at rlh151@aol.com for more glad to help--and let the suzuki lt 125 live on forever. my 125 also bogs down when i hit the throttle but i never knew what caused it so if you find something that helps let me know. later.
Robert Hammond---and one BAD Suzuki lt 125 RLH151@Aol.Com
Valves:
ex-26mm
ex-5.5mm
in & ex: .08-.13mm
in-.010-.037mm
ex-.03-.057mm
ex-5.455-5.470mm
thx for the info. It will help. I found that part of the problem was the jets in the carb. 3 of them were clogged. Then, the timing chain was off by a whole gear tooth. Part of that was my fault - the timing chain was so loose from stretching that I took 2 links out of it and when I put it back on, even though the spark plug was dead center, the timing lines were in the right place, a valve was in the open position. That made it hard to start and wouldn't let it power up. (Duh!) Having taken the time yet to fix the timing chain, but will have it done this weekend. Will let you know how it goes. Thx for the response and all the info. Am printing it for future reference!
Long live this 125 LT.....
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
CRamshaw777
Jul 18, 2015 05:46 PM
Mojave250A
Jul 11, 2015 10:38 AM
125, 1983, adjustment, adjustments, atv, carburetor, clearance, float, height, lash, lt, lt125, specs, suzuki, valve
