? for those with dynoports
Old Nov 27, 2006 | 11:09 PM
01vic99's Avatar
Default ? for those with dynoports
i was wondering what you are running for jets? I'm looking for a good starting point. I dont really want to call them to find out.
Old Nov 28, 2006 | 08:01 AM
ftwflh's Avatar
Start with a 280 and work down.You should end up with a 260 but with cold weather it may have to be fater than that.
Old Nov 28, 2006 | 08:51 AM
01vic99's Avatar
did you end up changing the pilot or messing with the needle?
Old Nov 28, 2006 | 11:52 PM
01vic99's Avatar
anyone else have any suggestions. Im really curious on the pilot jet.
Old Nov 29, 2006 | 08:05 AM
ftwflh's Avatar
When I ran the Dynoport I never had to mess with the pilot jet.
I would look into a clutch spring change.Like a Aaen blue secondary and a Dalton blk/white primary or if you want a little more engagment a Dalton blk/orange.
Old Nov 29, 2006 | 11:11 PM
01vic99's Avatar
thanks for the replys. i am only concered with the pilot because i do alot of plowing in the winter and dont want to hurt the motor. what clutch setup were you running with your dynoport?
Old Nov 29, 2006 | 11:23 PM
ftwflh's Avatar
I ran the Dalton blk/white with an Aaen blue secondary set at 2-2.If you plan on plowing you may want to run the stock primary with the Aaen secondary to keep the engagment as low as you can.
Wnthunting
Jul 19, 2014 01:51 PM
eurozx3
Aug 16, 2006 11:26 PM
Bill.Ciliberti
Mar 15, 2001 01:04 AM
