when do u use low on grizzly 660???
Old Dec 13, 2006 | 02:59 AM
hillrod's Avatar
Default when do u use low on grizzly 660???
when u use low on a grizzly?? i was pull a cupple of buddys on a hood through the snow and i have one on the back rack ... she kepet on rollin through about 5 in of snow and about 30-35 mph in a bean feild... would i use low for somehting like that, or just in deep thick mud or pulling really heavy dead weight load.. im not sure.. .... thanx jake
Old Dec 13, 2006 | 10:51 AM
2manytoys's Avatar
You should use low in the mud, pulling heavy loads, carrying heavy loads, or very steep hills. But it sounds like you did fine. If you pull too much you will burn the belt up.
Old Dec 13, 2006 | 10:55 AM
JDQuadRider's Avatar
I use low on my Grizzly in the following conditions:
*Towing regardless of weight. Saves a little wear on the belt.
*Long, steep hill climbs. Especially when I'm in a line with other riders.
*Plowing
*Descending steep hills. Results in better engine braking. I also use 4-wheel drive when engine braking.
*Deep mud or high water
Old Dec 13, 2006 | 01:06 PM
squeege's Avatar
I would think low range should be used to pull any of the overweight quads out of the mud....such as polaris, A/C, Bomb, ect...ect [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 13, 2006 | 01:13 PM
ilike2party's Avatar
YEah. i use low when pulling out A/Cs[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 13, 2006 | 03:47 PM
hoytultratec's Avatar
i only use it when pulling out yamahas and eigers[img]i/expressions/face-icon-small-happy.gif[/img]
ilike2party you stole my line about raging rivers[img]i/expressions/face-icon-small-disgusted.gif[/img] j/k
Old Dec 13, 2006 | 05:43 PM
you must be pulling out the old yamaha breeze, cause it aint one like mine[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 13, 2006 | 06:00 PM
DesertViper's Avatar
We had a few 660s before getting the 700 Grizz. I only used low range when climbing a hill that was steep enough to scare me into using low range. Yamaha belt drives don't require low range as much as the other brands. The 700 is even better than the 660s were, I think you could do just about anything in high range with the 700. Common sense, however, may prompt you to shift into low for the scariest of trail challenges, LOL.
DV
Old Dec 13, 2006 | 06:38 PM
mykool61679's Avatar
when climbing trees!! just kiddin!
Old Dec 13, 2006 | 07:11 PM
DV
what about a shear rock face?[img]i/expressions/face-icon-small-happy.gif[/img]
