Limited slip front diff on 300 4x4
Old Dec 17, 2006 | 12:48 AM
Tag75's Avatar
Default Limited slip front diff on 300 4x4
I have seen some other bigger models have a limited slip in the front then with the pull of a lever it is locked.
Is there a way to do that on my bayou 300 4x4?
Old Dec 17, 2006 | 07:22 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
What you have seen is a front differential lock - most of the big bore 4x4's have them. Your Bayou does not - it has a regular limited slip front dif. You can add a locker to most 4x4's.
Jaybee
Old Dec 17, 2006 | 11:11 PM
Tag75's Avatar
I am aware that it was a selectable locker. Heck I have a ARB selectable locker in my 4x4 truck. I was just hoping I could get one for the front of my Bayou.
Old Dec 19, 2006 | 10:03 AM
newbeatle's Avatar
you could likely swap out the front diffy, but to the best of my knowledge, you can not convert your existing one to a selectable locker... however, IMO, the 300's front diffy is a more heavy duty unit, as it was designed as a full time 4 X 4...
however in this day... anything is possible... but more likely your stock diffy unit could be machined to lock / unlock, easier than it could be machined to accept a clutch pack locker like the newer units have...
skinnyr6
Aug 25, 2023 02:18 AM
Ramman1
Jun 16, 2016 09:07 PM
TLC
Jul 25, 2015 02:24 AM
Reactant
Jul 16, 2015 10:29 PM
