500 Sportsman axle
Old Dec 19, 2006 | 08:16 PM
ZR900's Avatar
Default 500 Sportsman axle
I broke a CV joint and have the machine apart to the point that the remains of the front axle is hanging from the front differential. How do I remove this? If I give it a good jerk will it come out? Thanks
Old Dec 19, 2006 | 08:18 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats how you do it. sometimes you need to pry on it gently as well.
Old Dec 19, 2006 | 08:20 PM
ZR900's Avatar
Thanks
Old Dec 22, 2006 | 11:03 PM
BigDog800EFI's Avatar
Soak it for a day or two with penatrating oil and then give it one more day.
Old Jan 3, 2007 | 01:49 AM
STARKSREBEL's Avatar
if it is an older 500 you have a pin in the spline on the front differential.you need a rool pin punch to remove these.
Old Jan 3, 2007 | 02:13 AM
RickRitter's Avatar
A good yank or pry will remove it - it isn't pretty or fun . The housing is machined at an an angle on the inside to compress the clip - you'll see when you get it apart . There is no roll pin in that area to drive out .
Rick Ritter
Old Jan 3, 2007 | 02:21 AM
if it is a newer sportsman than you are right,if its an older sportsman it does have a role pin in the yoke on the differential splines!
Old Jan 3, 2007 | 07:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
ive never seen a roll pin on the axle except on the universle ends of the older ones.
Old Jan 3, 2007 | 09:33 AM
colt2245p's Avatar
its on my 01. it is about 5/16 or a 1/4 inch roll pin. its a b!tch to drive out but once you do the axle pulls right out
Old Jan 3, 2007 | 03:55 PM
you can buy a set of roll pin punches at sears for $20. i am assuming that he wants to remove the whole axle and no just the cv joint.
