2003 400ex idling problems
Old Dec 28, 2006 | 10:15 AM
WXHITMANXW's Avatar
Default 2003 400ex idling problems
I have a 2003 400 ex with white brothers pipe high performance cdi box and stage 2 cam staock carb with 168 main jet. It will idle fine cold but once it is ridden for a little while it idles between like 1500 and 2000 rpms. is their an adjustment on this carb to fix that?
Old Dec 28, 2006 | 12:12 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Big **** on the left side of carb (towards the front). It is slotted, but is serrated and big enough that you can trun it by hand if you need to adjust it out on the trail.
Old Dec 28, 2006 | 12:28 PM
WXHITMANXW's Avatar
I dont recall of seeing a big **** on the carb when i put the jet and needle in it, but i would turn it clockwise to bring the idle down correct? would the air fuel mixture screw have any thing to do with it?
Old Dec 28, 2006 | 01:06 PM
hondabuster's Avatar
The mixture screw may be ok where it is, but it sounds like the idle speed setting may be a bit high, or the clamps holding the carb may have loosened up, and now youve got a air leak, which raises the rpms.
Check to make sure the carb clamps are still tight. Then try backing the idle screw out a bit.
Old Dec 30, 2006 | 08:37 AM
WXHITMANXW's Avatar
found the **** guys thanks. it soesnt look like it would be an idle screw due to its location.
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
