bigred spark just dies
Old Jan 5, 2007 | 04:45 PM
BIGREDRIDER2233's Avatar
Default bigred spark just dies
i was riding one day and my three wheelr just shut off... i pulled the plug out and no spark
went through like 3 plugs and it wasn't that. and its not the coil i changed itwhat could it be?/
Old Jan 6, 2007 | 10:03 AM
wrestleu's Avatar
Sounds like the CDI to me. But could also be the primary stator coil.
Old Jan 8, 2007 | 06:38 AM
2FAST4URASS's Avatar
PULSER TRIGER / SOURCE COIL..
Old Jan 9, 2007 | 09:26 PM
wat is the PULSER TRIGER ??
Old Jan 9, 2007 | 09:30 PM
ITS A LIL box that runs off that stater coil it sends the signal from the stater-coil to the coil it self!!!!
Old Jan 16, 2007 | 10:37 AM
i changed the pulster triger and the coil where is the cdi??
Old Jan 16, 2007 | 08:19 PM
popup's Avatar
if you have a 250 bigred its under the left side cover.the cdi is black about 2" long with a 5 or more wire plug. the 200 big red cdi is under the gas tank. left side black about 2"long with 5 or more wire plug. you will have take the gas tank to get at it.
Old Jan 31, 2007 | 10:02 PM
mark38090's Avatar
I just had the same problem with my 250sx, I replaced the cdi and solved the problem.
Old Feb 2, 2007 | 02:28 PM
nope wasn't that ive replaced the coil and the cdi and nothings working. i checked all the wires and nothings disconnected or anything.. im stumped on this one
Old Feb 2, 2007 | 06:24 PM
popup's Avatar
your on off switch or the stator?
