How many PSI of compression on a V2
Old Jan 5, 2007 | 08:52 PM
sammydogs64's Avatar
Default How many PSI of compression on a V2
What has anyone checked the PSI on thier 650 or 700 Prairie/Brute force motor? I have an AC650 V2 and I am only getting 80 PSI, this sounds real low from my experience with sleds in the 140-150 PSI range. This was tested with a Craftsman guage so it should be somewhat accurate.
Thanks
Old Jan 5, 2007 | 09:38 PM
mizer's Avatar
its hard to tell because that motor has decompression built into the cams that keep the compression down for easy starts.
Old Jan 6, 2007 | 10:39 AM
v2rider's Avatar
There is alot more performance coming from a sled. You should have alot higher reading out of a sled than an ATV
Old Jan 6, 2007 | 07:56 PM
I pulled out the Shop manual from my old Prairie 650, it clearly says 47 - 81 PSI is the normal range, so I guess I am OK
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
