fuel shutoff
Old Jan 10, 2007 | 02:58 PM
sodak's Avatar
Default fuel shutoff
I have a 06 650i bf wich is completely stock that I would like to put a shutoff on. I have had it hydro lock 2 times after having had it trailered. I think for long hauls the floats bounce letting fuel by filling the jugs. What size shutoff do I need and where is the best place to put it so I can reach it easily. Thanks in advance.
Sodak
Old Jan 10, 2007 | 06:17 PM
Hayashi's Avatar
Before installing the fuel shut off, do this experiment:
When loading up your quad onto the trailer next time, change the orientation of the quad on the trailer.
For example:
1). If you normally head-in, then back-in.
2). If you back-in, then head-in.
3). If you load it up sideway (transversed), then load up longitidunal (either head-in or back-in).
I've seen the same problem on other quads, this worked for me.
Old Jan 11, 2007 | 09:12 AM
quadog's Avatar
Check to see if your fuel tank vent is clogged. Fuel may be forced by your float needle if pressure is not allowed to vent.
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
