Another Kazuma question...
Old Jan 12, 2007 | 10:26 PM
ElDiablo's Avatar
Default Another Kazuma question...
Hi everyone, I'm new here so hello. Here's my question...I have a Kazuma Falcon 150 and after being out in the bush I did a regular check on the ATV and noticed that the right tire (looking from in front of the atv) was toe out, whereas the left was perfectly straight. Is there a way to adjust this? any help would be greatly appreciated thx....
Old Jan 12, 2007 | 11:14 PM
2manytoys's Avatar
Yes all you have to do is losen the nuts on the tie rod ends. Once you do this you can turn the tie rod in or out to adjust the toe then tighten the nuts.
Old Jan 13, 2007 | 11:59 PM
ARCHERIC's Avatar
Hello ElDiablo welcome to the fourm
2manytoys is right and it's not hard to do.
Not getting on you but always remember that when you give the side of a vehicle it's when you are sitting on or in it.
so it will be the left front tire that need's the alignment adjusted.
one thing you need to do is make sure the castle nut and carter pin is tight , you might have to shim it with washers, I had one come apart and lost the carter pin and nut while riding too fast.... I thought the World had come to the end !
non-sunday school words were spoken !!!!!
you need to chech every nut and bolt on the ATV and make sure they are tight.
Archeric
06' Kazuma Dingo 150
Old Jan 15, 2007 | 05:23 PM
ElDiablo's Avatar
Thx every1 who answerd I'm going to give it a try and let you guys know what happens....
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
QuadCity
Aug 13, 2015 12:58 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
michdagh
Sep 19, 2002 05:32 AM
