Valves adjust on 04 foreman
Old Jan 14, 2007 | 09:28 PM
old's Avatar
old
Default Valves adjust on 04 foreman
Hi all, i need to adjust the valves on my foreman and know that the clearance is .006 ". Is that set at TDC on both valves? Or what is the honda procedure for this. Thanks
Old Jan 15, 2007 | 12:13 AM
1988TRX250R's Avatar
Remove the valve cover so you can watch the valves while you turn the motor over. The exhaust will open first, and then before it completely closes the intake will start to open. After the intake closes watch for the timing marks on the flywheel. There will first be an 'F' and then a 'T'. Stop at the 'T' mark and that is TDC. Make sure there is slack in the valves and adjust both of them.
Old Jan 15, 2007 | 06:52 AM
old's Avatar
old
Thanks for the info.
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
Jul 22, 2015 05:00 AM
