HELP!!! Honda Foreman 450 04
On my 04 foreman 450 es after about 5 minutes of riding my four wheel drive light will flash 4 times with one second intervals than a slight pause and start over. While this is happening i loose four wheel drive. If i restart the four wheeler 4 wheel drive with engage for about 5 minutes. Around the same time that this happened my fan stopped working. I ran a cable from the fan to the battery and the fan will work. I am assuming that is a temp gauge. Will that cause my four wheel drive to stop working? I mounted a rocker switch on the handle bar to engage the fan. Is their a way to reset the code.
