06 p360 4x4 stalling problems
Old Jan 15, 2007 | 09:42 PM
mudlite191's Avatar
Default 06 p360 4x4 stalling problems
when i start my quad its fine even in cold weather but even when its warmed up and i start to stop it will stall. I have to keep my hand on the throttle. i adjusted the carb so that is more richer but it still does it.
Its realy anoying when your just trying to have a good ride can anyone help me thanks.
Old Jan 15, 2007 | 10:52 PM
harry1's Avatar
I'm no pro on these things but this specific problem has come up before on this forum....have you set you valves? A few of the notes I've seen concerning similar problem has to do with the exhaust valve tightening up as the motor heats up and the valve no longer fully closes. Someone will back this or refute this for you but this is what I've heard.
DaveP
Old Jan 15, 2007 | 11:45 PM
mudlite191's Avatar
thanks
Old Jan 15, 2007 | 11:59 PM
alwaysride's Avatar
Getting your valves adjusted should solve the prob. I get mine adjusted once a year. If i let them go to long, it just starts to do way to easy.
Old Jan 16, 2007 | 12:11 AM
mudlite191's Avatar
is there a web sight on how to adjust the valves and do i tightin them or loosen them thanks
Old Jan 16, 2007 | 09:02 AM
harry1's Avatar
loosen them
Old Jan 16, 2007 | 09:12 AM
mudlite191's Avatar
so whenn i go to adjust them they should be very tight andi should loosen them and is this an easy task. thanks
Old Jan 16, 2007 | 04:20 PM
ColdKaw's Avatar
Hey Mudlite, I have an 04 360 , and i had problems with the bike being hard to start, and it wouldn't idle until it was good and hot. I adjusted the exhaust valve and it runs great now, even idle when it's cold.
It sounds like you may have a different problem. Does your bike idle when cold?
You may need to check the engine brake actuator, it can make the engine stall if it doesn't release when you slow down.
You can download the complete service manual for your bike from the following web site , what a deal! FREE.
Good luck with the repairs. http://www.mmi.org/merrington/atv
Old Jan 16, 2007 | 09:31 PM
mudlite191's Avatar
hey thanks i just checked the valves and adjusted them and im going take the brake thing out i think thats my problem thanks for the web sight.
Old Jan 16, 2007 | 09:40 PM
ColdKaw's Avatar
Cheers! This is a great forum for info and getting tips from other riders.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
southbayman
Jul 24, 2015 09:30 AM
hondarider1234
Jul 21, 2015 11:53 PM
