Time for a new back sprocket??
Old Jan 16, 2007 | 05:44 PM
Billy08's Avatar
Default Time for a new back sprocket??
I was looking at the back sprocket the other day on my Atc, and i noticed that the teeth are all bent slightly to the left. I was planning on getting a front sprocket anyway, and if i do so, i dont want to ruin it because of this problem.Do anyone know if the slight bend is all that big a deal, also does anyone know the price range on a new rear sprocet for a 1985 200m atc. thank you.
Old Jan 16, 2007 | 08:08 PM
JLsparky7's Avatar
Try www.rockymountainatv.com for the prices, they are the cheapest around.
The general rule of thumb is if your gunna replace one, replace all three (2 sprockets and chain) because each has a different wear pattern. The cost of a cracked engine case is not worth the chance (supposing your chain breaks). Replace both sprockets and the chain, you can get kits for around 130-140 bucks I beleive.
If however you do want to go the cheap route, flip the sprocket that is getting "shark toothed" around and replace the other one.
I accept no responsibility if you mess yourself, someone else, or your quad up.
Old Jan 16, 2007 | 08:49 PM
Billy08's Avatar
I searched that site that you told me about and i couldnt seem to find any results for the 1985 200m, i was wondering if any other models sprockets would fit a 200m.
Old Jan 16, 2007 | 09:07 PM
JLsparky7's Avatar
Im not sure which other years will fit that quad. Your best bet is try and find a closeup picture of a sprocket you think will fit.
You could also take the sprocket into a dealership and ask to look at other ones that might fit. Then write down the part number and buy it online. We all know stealerships are pretty much worthless.
Old Jan 16, 2007 | 10:24 PM
Billy08's Avatar
Thanks for the imformation, if i cannot find a sprcoket to fit it i will try to turn the sprocket around. Have you ever turned the sprocket around or heard of some one that did it before, if so could u tell me how it worked,, thanks agian.
Old Jan 16, 2007 | 11:55 PM
JLsparky7's Avatar
I recently turned the front sprocket on my R6 around. It only had VERY slight shark toothing. I did it just because the chain and rear sprocket have been changed but the front sprocket was kept stock.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
merryman
Jun 15, 2015 02:36 AM
cornermike
Jun 3, 2015 07:27 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
