Please Help!!! raptor 06
Old Jan 18, 2007 | 12:21 AM
brett16's Avatar
Default Please Help!!! raptor 06
ok so i started up my raptor today and let it warm up for about 5 minutes or so i took it out for a rip around the block came back and let it run for a bit longer. i turned it off and decided to check my oil and the oil pan was overflowing right to the top!!!! it had a hint of gas in it. does anyone no what is going on or what i should do. I just recently did an oil change and everything was running fine. its an 06 and hasnt been riden a whole lot [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 18, 2007 | 12:47 AM
JLsparky7's Avatar
Sounds like the same prob all the 700efi's have been having. Either there leaking gas into the oil or not starting. No offense but thats joys of owning a 1st generation vehicle.
Old Jan 18, 2007 | 12:50 AM
brett16's Avatar
what can u do about it to fix it? couldit possibly be bad gas ?
Old Jan 18, 2007 | 08:06 AM
Ozark38's Avatar
Do you have mods or is it totally stock?
Old Jan 18, 2007 | 11:22 AM
brett16's Avatar
i just have a procircuit slip on pipe and the power commander3 i am running the correct map could it possibly be giving the enging to much gas? I think i might drain all the gas and change the oil but put stabilizer in my gas this time around does anyone think this would help? its all i can think of right now, unless somthing is wrong with the injectors[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jan 18, 2007 | 06:12 PM
Ozark38's Avatar
I think its a common thing like sparky said. Mine also does this. I don't think fuel is leaking in anywhere (where would it come in at?) but I just think most of us are running them too rich and fuel is getting past the rings into the crankcase. I know a couple guys running Dobecks had them dyno tuned and their settings are a lot less than mine are. Another prospect could be the cold mixture. These things run extremely rich during warm up. So rich that a lot of people have fouled out plugs trying to ride them during warm up. All I know to do is change the oil more often and try to let it warm up before you ride. Maybe try leaning out the mixture a little bit.
Old Jan 18, 2007 | 07:00 PM
fasterthanyou22's Avatar
Check your plug for any kind of material on it, like sludgy stuff. Since the raptor is a longer stroking motor, if it runs richer once the fuel gets away from the sparkplug it can have a tendency no to combust. You should get a prodesign intake for more air, and try running the same fuel map. If the bike runs fine still, then it was rich before you got it.
Old Jan 18, 2007 | 09:35 PM
brett16's Avatar
alright so today i drained all my gas and oil filled everything back up for a new spark plug took it out andeverything ran just fine, i didnt take it out for too long. ill start er up again tomorow and see how things go. Thanks for the advice its greatly appreaciated.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 19, 2007 | 11:01 PM
hondaeater69's Avatar
i have a raptor 700 new and it runs bad in cold is that normal
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
