CARB FOR 125CC SUNL TRANSPORTER
Old Jan 18, 2007 | 10:46 AM
MAS's Avatar
MAS
Default CARB FOR 125CC SUNL TRANSPORTER
GREETINGS: ANY ONE STEER ME IN THE RIGHT DIRECTION TO FIND A CARB FOR A SUNL 125CC TRANSPORTER.
CARB WAS DEAD ON ARRIVAL ON 14 DEC, 2006 AND DEALER JUST KEEPS TELLING ME ITS ON ORDER.
I,M READY TO SPEND MORE MONEY JUST TO SEE IF IT RUNS.
ANY HELP WILL BE APPRECIATED
THANKS
Old Jan 18, 2007 | 11:12 AM
YankeeTim's Avatar
sunl.com
Old Jan 18, 2007 | 01:58 PM
billl2099's Avatar
again someone's not paying attention,, for parts for your sunl give raceway a call. they're be more than happy to help you out. by the way it does'n't need to come from sunl any carb from any chinese 125cc will work, they're all the same.
Old Jan 18, 2007 | 10:43 PM
2manytoys's Avatar
MAS
First off what makes you think the carb is bad? What problems are you having? It may be a simple problem.
Old Jan 19, 2007 | 10:14 AM
MAS's Avatar
MAS
GREETINGS; WHEN I PUT GAS IN TANK, GAS FLOWED OUT OF CAR DRAIN TUBE ONTO GROUND. TIGHTENED DRAIN SCREW, DID NOT STOP GAS FLOW. STOPPED UP DRAIN TUBE, GAS FLOWED OUT OF AIR FILTER. REMOVED CARB, CLEANED CARB, BOWL, FLOAT, DRAIN SCREW, DRAIN SCREW OUTLET. GAS STILL FLOWS. FLOAT DOES NOT STOP FLOW OF GAS . NOT THAT EXPERIENCED WITH CARBS OR FLOAT ANY HELP IS APPRECIATED.
Old Jan 19, 2007 | 12:10 PM
9kids's Avatar
You are right you have a problem with the float. The float has a small metal tab close to where it is hinged. This tab pushes against a needle valve. The needle valve has a small pencil shaped needle that may have a rubber tip. As the gas fills up the bowl the float rises and the metal tab pushes the needle up and the tip of the needle plugs the hole stopping the gas from flowing. Things that could be wrong are; the hole that the needle is supposed to plug may have debris in it, not allowing the needle to raise up; there may be debris around the needle so that it can't slide up and down; or the metal tab on the float is designed to be bent up and down to adjust the level of gas in the bowl, if it is bent way down even when the float rises it will not push the needle up far enough to stop the flow of gas. You should take the carb back off, take the float bowl off and visually check that everything is working as I described above. If you don't see anything obvious then you might have to get a little messy, get plenty of rags and no smoking, put the carb back on with out the float bowl on, hook up the gas, turn on the gas valve and gas should pour out the bottom of the carb, push up on the float with your finger gently, gas should stop, if it does not, shut off the gas valve and then slide the float hinge pin out and take the float off, be ready for the needle to fall out, put the needle back in its hole and push up on it with your finger, now turn the gas valve back on, if gas still pours out, then there is probable some debris keeping the point of the needle from plugging the hole, if the gas does not flow then the problem is the metal tab on the float not pushing the needle up far enough. I am assuming there is a gas valve on the bottom of the gas tank or in the line but not all Chinese ATV's have them, so if not, it would make this test more difficult. Hope this helps
9Kids
Old Jan 19, 2007 | 01:38 PM
MAS's Avatar
MAS
THANKS FOR THE INFO WILL TRY ALL THIS WEEKEND. LET YOU KNOW WHAT HAPPENS.
MAS
Old Jan 20, 2007 | 09:14 PM
MAS's Avatar
MAS
SOUNDS LIKE A START, WHAT DO YOU WANT FOR IT?
Old Jan 20, 2007 | 09:25 PM
MAS's Avatar
MAS
I HAVE E-MAILED YOU
WARREN MASON
Old Jan 21, 2008 | 07:50 PM
TBMOTO's Avatar
Yes, my name is Tom Peak, I am with T & B Motorsports of Louisville, KY and I am the man to come for to get answers to your questions of any SUNL products. I currently have in stock the Carb you are looking for. Feel Free to EMAIL me or you can give us a call 1-877-4TB-Moto or visit our site at www.tandbmotorsports.com , I would be glad to help you in this situation, also we are the answer to any other SUNL problems you may have.
