lt 80 flooded
Old Jan 19, 2007 | 07:00 PM
kent's Avatar
Default lt 80 flooded
Im thinking I have a problem with the petcock, but not sure. I put a new plug in and it was very wet with gas. When I do get it to crank it bogs for a little while then it runs fine. I put new reeds and a different carb on, it has a 20mm carb, and it still wont crank. It is getting too much gas from somewhere. If it is the petcock how do I fix it.
Old Jan 19, 2007 | 07:45 PM
carlw's Avatar
petcocks fail a few ways.
leaks externaly
cloged with crap and wont flow fuel
stuck open or closed.
none of these things will make your bike run rich or flood.a bad float needel in the carb or crap hanging up the float needel is usualy what it is.
Old Jan 20, 2007 | 11:13 AM
LT80's Avatar
LT80 Expert
Seeins you have the 20mm on it, you use the petcock as an on/off petcock now as there is no vaccum to run the petcock.
Prime=to run the motor
On= will shut the fuel off now.
I'm not a big fan of the 20mm's but they run ok.
What's the compression?
Old Jan 20, 2007 | 05:03 PM
kent's Avatar
I just put a new piston in a few months ago. It has plenty of compression. Could it be possible I may have an electrical problem causing it have a weak spark. I thought it may be the stator at first. When I do get it started it runs fine. It has really got me stumped .
Old Jan 22, 2007 | 11:58 AM
LT80's Avatar
LT80 Expert
Seems an ohm meter is needed to check the resistance on the stator and coil. Sorry i don't know the specs. One is 175-185 but I forget which one,.[img]i/expressions/face-icon-small-blush.gif[/img]
Customer Service #1
May 15, 2020 08:46 AM
Jason Poulin
Sep 20, 2015 02:49 AM
Jaymc
Sep 11, 2015 07:45 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
1000gade
Jul 16, 2015 10:48 AM
