04' Warrior Idles high unless E-brake engaged
Old Jan 22, 2007 | 12:34 AM
DH1974's Avatar
Default 04' Warrior Idles high unless E-brake engaged
My wifes 2004 Warrior idles high unless I engage the E-brake???? I have adjusted the idle srew and it still won't come down. Any suggestions?? Could this be a problem with the E-brake and not the idle??
Old Jan 22, 2007 | 02:18 PM
DH1974's Avatar
BUMP - Anyone??????
Old Jan 22, 2007 | 03:28 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
your choke is stuck
Old Jan 22, 2007 | 04:36 PM
lucasislight's Avatar
take off the useless ebrake, causes more headaches than anything, take it all off, get a blockoff plate for the caliper and unplug the sensor switch/wire from the clutch perch.
Old Jan 22, 2007 | 07:13 PM
JLsparky7's Avatar
Thats what I would do.
Old Jan 25, 2007 | 07:24 PM
DH1974's Avatar
Do I just unplug the wire connection at the perch or do I need to splice any wires together or plug it in somewhere else??
Old Jan 25, 2007 | 08:03 PM
Speedy2222's Avatar
there's 2 that plug into each other.. the other just hang
Old Jan 25, 2007 | 10:24 PM
unplug it from the perch then follow it down about a foot and you can unplug the other end. i never spliced mine and my problems went away, just wrapped it in elec tape to keep the crap out. i think its the button on the wire you will remove that causes the problems?
Old Jan 25, 2007 | 10:25 PM
i hear alot of people splicing them though, but i dont know crap about elec!
Old Jan 25, 2007 | 10:27 PM
Speedy2222's Avatar
you don't splice anything.. u don't even have to wrap them.. there 2 wires that plug into each other and those plug rgiht into each other..
