440 EX big bore reliability?
Old Jan 27, 2007 | 03:06 AM
ATVnewbie2's Avatar
Default 440 EX big bore reliability?
I am thinking hard about doing the 440 big bore kit on my 04, how are they for power and reliability? I also have a slip on exhaust system (HMF BB carbon with a stock header), is that OK or do I have to get another aftermarket header? Thanks in advance
Old Jan 27, 2007 | 09:10 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Are you doing this because you want more motor, or because it is worn out and you need to bore it anyway???
I would say that we see a lot more problem posts from people who have 440's than we see from folks who are stock..........
Old Jan 27, 2007 | 11:56 PM
JLsparky7's Avatar
Go with a stroker.
Old Jan 28, 2007 | 12:07 AM
TractorPacker's Avatar
Do you have a balloon?
There has been some problems with the 440. They are mainly head gasket and head studs. The higher the compression, the sooner the problem. If you stay below 11.5:1 compression, the 89mm(436cc) will hold its studs. Sparky says to stroke it. I agree if you can afford it. I have an 87mm stroked 4mm. It is a monster and has ran for about three years. The only problem I have is with worn out grips. The stroker is about 800 dollars more, though, once you split the cases and what not.
shimanok2
Jan 29, 2016 07:37 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
01ssls1
Sep 22, 2015 06:50 AM
