Riding a wheelie question
Old Jan 29, 2007 | 01:41 PM
Oddy's Avatar
Default Riding a wheelie question
When riding a wheelie on my warrior it pulls to the right always,ive tryed making sure tires pressure is even and ive even pumped my left tire with more air and ive tryed leaning and turning my handlebars a certain way and it still pulls to the right ,its really anoying becuz ill be riding a wheelie and ill have to stop becuz ill hit sumthin or go offtrack if i dont.lol any ideas wud help
Old Jan 29, 2007 | 02:03 PM
Raptor660JC's Avatar
Might not be noticable but your axle might have a slight bend in it. Check it out
Old Jan 29, 2007 | 03:18 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
if your chain tensinoers are off it iwll do that..
Old Jan 29, 2007 | 05:50 PM
Dwags's Avatar
tire press. or axel carrier, not bent axel bc w/axel bent it would just vibrate even when not wheeling
Old Jan 29, 2007 | 06:04 PM
GingerLove's Avatar
I had an 88 Warrior that did the same thing .I never found what was wrong with it .
I changed the things in the back for the chain,I tryed the whole frame thing ,I took it to 3 shops and spent over $1,000.in parts and shops trying to find out why it dose that.
Ill I can say is good luck.
Old Jan 29, 2007 | 06:28 PM
Speedy2222's Avatar
it also may be your style of tire too..
Old Jan 29, 2007 | 08:19 PM
Raptor450's Avatar
Id just let some some air out of the left tire until it goes straight. If the ground is unlevel to the left or right that will make it walk to the right. If your tires are uneven in wear, that will also make it do it. All this as well as what everyone else said should help you out.
Old Jan 30, 2007 | 08:57 PM
fasterthanyou22's Avatar
Swingarm bushings might be going bad.
Old Jan 30, 2007 | 09:49 PM
lucasislight's Avatar
i agree with fasterthanyou22 everything else looks straight, but the swingarm might me walking a little...
Old Jan 31, 2007 | 02:37 AM
Raptor450's Avatar
I agree the swingarm bearings are probably shot, but I dont think that would cause it to walk one way or the other. I just replaced mine and they were in BAD shape. All the rear shock bushings, linkage bushings, and swingarm bearings were shot. I still didnt have any problem keeping mine straight on a wheelie. I think its a tire pressure issue. Read the thread carefully. It says it pulls to the RIGHT, but he ADDED air to the LEFT tire. If it pulls to the right, add air to the right tire, not the left, or either let a little out of the left tire. Anything with 4 wheels always pulls to the direction of the tire with the LEAST amount of air.
